SetCoordinateSystem (IMassProperty)
hello, i need to do an interface between MSExcel and SolidWorks using MSVisualBasic to calculate the mass properties from different coordinates systems. i need exactly to do what the function SetCoordinateSystem does: set the coordinate system to use when calculating mass properties for a model.
i have a lot of problems because i am a beginner using visual basic...
i have checked the APIhelp and it gives me this information
_____________________________________
Visual Basic (Declaration)
Function SetCoordinateSystem( _
   ByVal Coords As MathTransform _
) As Boolean
Visual Basic (Usage) Copy Code
Dim instance As IMassProperty
Dim Coords As MathTransform
Dim value As Boolean
value = instance.SetCoordinateSystem(Coords)
______________________________________________
in the other interfaces i have done, i was just copying examples from APIhelp, but in this case there isn't any example and i don't know what to do with this information.
i know i have to change IMassProperty for Object, when i am using it on VB, but i don't know what to do with MathTransform nor Coords, and i don't know neither what they mean.
any help will be very welcome. thanks!
