Retro-fitting regulators
I am looking to replace the regulators for my assist gas system, so the shop can clean cut stainless steel. The current SMC regulators only push out a maximum of 8 bars and i would like to see 20 bars. I can't find anything from SMC besides what I already have and other internet sites offer no help with high pressure. I am running a mazak with a 1500 watt PRC resonator. If possible I would like to clean cut 1/4" stainless. (PRC claims this is possible with 1500W) Any help with the regulators would be appreciated, also please let me know if the 1/4" is a reasonable thought.
RE: Retro-fitting regulators
For a while there PRC was doing an up grade to that style laser. They added bigger heat exchangers and a different turbo and got 2000 watts pretty consistently. There is a guy named Mark that works on a ton of PRC's. I believe he is in the MSP area.
When i get a chance, i'll look to see what type of regulators Amada uses. I know they go up to 2 MPa.
As for the assist gas, what are you going to use to supply the assist gas? 12 packs, liquid tanks? How many regulators are in the current configuration? Most systems have 2 regulators, one to control pre-pressure and then another, possibly electrically controlled regulator to set the desired pressure for the specific application.
Chris Krug http://krugtech.com/
Hope this is of some use for you.....
