Problems with Abaqus Packager
Hello all,
I want to bring out a strange case that has been happening with my job.
I have modelled the Ladaveze model for composite failure in a Vumat routine. The model is for plane stress formulation.
I have created a shell geometry the usual way and doing a single element test selecting Plane stress element. I'm running dynamic explicit analysis.
While data check or submit stage, I see that the Abaqus packager starts and runs indefinitely. Even if I try to kill the job it doesn't respond. Th only way is to end the process from task manager.
Any idea what might be going on? It is as if Abaqus has gone on an infinite loop.
Any help would be great.
cheers
Sujith
RE: Problems with Abaqus Packager
This situation has been resolved. The error was casued due to a mismatch in the property data.
