Cost of a 35.000 BPSD atmospheric unit ?
I`m making a bid estimate of a crude atmospheric unit. The equipment has a capacity of 35.000 BPSD, with a 48ºAPI crude (I have the TBP curve). The main products are light and heavy naphtha, kerosene, diesel and GOA.
Does any one know where I can find that cost.
Designers and manufacturers of towers, websites or books.
I know that the cost of a equipment depends on a great many variables, such as: location, pressure, temperature, etc, nevertheless, I`m asking for a bid.
RE: Cost of a 35.000 BPSD atmospheric unit ?
The best way to obtain an accurate cost estimate is from some of the major refinery engineering and construction companies like Fluor, KBR, Bechtel or Jacobs ... just to name a few.
Milton Beychok
(Visit me at www.air-dispersion.com)
Very rough order of magnitude is about $1500 per bbl.  At that size unit the big E and C s will laugh at you.
35,000 bbl/day is a nice size tower, say 3 meters in diameter.
I have another question, is this $1500 per bbl for purchased, delivered, set-in-place or installed equipment?
I made a simple simulation using Aspen and I got a diameter of 5 meters, is this rather much?.
Thank you in advance
Cost for modularized refinery is $1000/bbl ex works.  Needs to be transported, installed and hooked up.  Does not include u and o.  35,000 bpd used refinery has 11' id atm column.
Correction that is a 30,000 bpd.
