Constant-velocity telescopic cylindersùdesign fundamentals
I am having difficulty finding good-quality resources that explain the workings of constant-velocity telescopic hydraulic cylinders. I need to develop some understanding, not just learn to copy a mysterious schematic. This doesn't need to go into great depth, but must account in some detail for the pressure distribution across cylinder segments. Thanks in advance for any advice!
RE: Constant-velocity telescopic cylindersùdesign fundamentals
http://for
... which makes it appear that _perhaps_ someone has figured out how to make what you want, but they may not have found a market for it.
Just to attract the attention of any manufacturers who might consider entering the business, how many thousands of these devices are you prepared to buy?
Mike Halloran
Pembroke Pines, FL, USA
I'm also surprised to see that most of what little traffic there is on this topic involves issues of novel design (eg: special projects). But the stark fact is that these devices already exist and are in service; we know this because
(a) the manufacturers list them, and
(b) we are troubleshooting an existing machine
So we are not talking about exotic design challenges or special equipment, just machines that are not ubiquitous. Of course it's as obvious as night follows day that in the end, we may have to consult the manufacturer. However, before doing that, I naturally would like to acquire a basic knowledge of the workings of the device! After all, when the technician asks my opinion, it would be pretty lame of me to just shrug my shoulders and palm it back to the manufacturer. The point of posting here is to try to educate myself in the basics of this particular type—not brand or model—of cylinder. I have a general idea of the internal geometry, but I am after a basic explanation of its operation, in the same way that we have a generic understanding of the workings of NON-CONSTANT-SPEED telescopic cylinders. In those models (which are very common), the stages extend in order of decreasing effective piston area. In the constant-speed type, internal ports pass fluid to the side of each stage—until it is fully extended—into a volume that is equal to the annular area of the preceding stage. It's an interesting design!
http://en.wikipedia.org/wiki/Telescopic_cylinder
parrots the text of the magazine article it references for constant thrust telescopic cylinders. Neither includes a section, or design rules.
Mike Halloran
That would put us on track—a nice clear section and some design rules. Yes, the Wikipedia article gave me that old circular feeling too.
A Swedish uni page has one interesting section (p7) that compares constant-thrust and regular telescopics:
htt
But I can't quite make enough of that to work out the design rules myself.
Eventually I came across the Parker (Commercial) catalog, which has some useful sections, and separately in several places a suggestion that constant thrust telescopics may be designed and built in some unmentioned magical way, OR just by jiggering the effective areas of all the sections so they are equal. Perhaps that is sufficient.
Mike Halloran
The check valves in the pistons force the annular flows into the stage piston areas. Each annular area equals the ajacent stage area. The veloctiy of the rod end 'p' is the sum of all stage velocities. By operating area equallity, each stage velocity equals v1. So the velocity of 'p', vp = v1*n. v1 = q1/a1.
It would seem then that if any check valve malfunctions open the stage above the valve would not move at v1. Flow from the annulus area would flow back to the previous stage. It would act like a standard telescoping cylinder. Or some confused motion if the check valves chattered.
Make sense? Interesting. I have never had occasion to look into this type cylinder.
Ted
