connecting very thick shell elements
I am modeling a very thick concrete slab which has a deep beam (both of them are shell elements). For considering the differences in centerlines I made an offset between beam and slab joints. My question is that how can I use body constraints to make the connection between beam and slab joints.
If I select all the joints along the boundary of slab and beam and assign a new body constraint to them to make a connection it acts as a rigid support and it ends up with no deflection in constraint joints which is not realistic because these joints are part of slab and should have reasonable deflections.
Thanks for your help
RE: connecting very thick shell elements
Try to attach the file.
I think I found the problem. Instead of selecting all the joints along the beam and slab boundary and assigning just one body constraint to them, I have to select each two joints that should connect to each other and assign a new body constraint to them.
how can i connect a beam ( I4" - space 1000 mm ) in a wall 3/16" (5000 x 5000 mm) ? using constraints..?
thanks
betopira
