Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I also believe that we all can contribute to each other's growth by sharing knowlege and experiences. I would love to take my skills and help people around the world solve problems..."
Geography
prototypingfool (Electrical)
9 May 10 12:56
I've measured my prototype antenna using a known Reference Log Periodic. Test set up was the known Log pointing at my prototype Antenna Under Test (AUT) using S21 on my VNA.Cable length was calibrated out.
How do i determine the AUT's gain in dB or dBi? I thought,
i took the LogMag measured data (i.e. -30db), and subtracted the free space loss (say +40dB) and my reference antenna gain (+4dB). Would this yield:
AUT (dBi) =  40-30-4 = 6dB or +8.14dBi???
VE1BLL (Military)
10 May 10 11:17
How does the tolerance (accuracy, stability, repeatability, multipath, interference) of your estimated pathloss (free space loss) compare to the tolerance required of you calculated gain? For example, if the pathloss is 40dB, but this is +/- 1.5 dB.
How about using a third antenna and *comparing* it to the known (?) gain of your reference log periodic antenna to the AUT?
And, with three antennas, then you could also perform the three-antenna self-calibrating method.
And then compare all these various results to see if they all align.
Sounds to me like a couple of fun days at work... smile
Higgler (Electrical)
10 May 10 18:53
Look up Friis equation.
Measure S21 with full two port calibration.
Measure at three different lengths from your Log Periodic to your unit under test and compare the answers for all three lengths with the Friis equation.
The 3 antenna method is good too, it all depends on your environment whether it's clean or not.
Close Box
Join Eng-Tips® Today!
Join Us             Close
