Titanium stringers in 321 tainless steel
What causes titanium stringers in 321 stainless steel?
Is 347 (niobium stabilized) preferable?
Material requirement should contain 0.01%Co & 0.08%Mn ideally.
Any info 321 versus 347 would be appreciated.
RE: Titanium stringers in 321 tainless steel
Why on earth would you want 321 for this? Low carbon will achieve the same thing with a cleaner alloy.
You will always get agglomeration of carbo-nitrides, Ti or Nb it doesn't matter. There will be some banding or stringers.
Plymouth Tube
If there is a large amount of cold work you can break up the agglomerations. Plate of tubing without much cold reduction can show significant banding.
Plymouth Tube
