API 8C and fatigue
API 8C and fatigue
API 8C and fatigue
We have a weld assembly that falls under API8C, it is load tested then MT'd. If it fails the MT it is weld repaired because it is welded it has to be reload tested.  This goes round and round causing fatigue, what should we do?  Has anyone else encountered this situation?
