Does 13.37 cfm of water translate to 100 gpm of water?
I have a question for you brainy types:
If I have a storage tank full of water with an air supply to the top regulated at 50 psi @ 13.37 cfm, and a sprinkler system fed off the bottom of the tank that's hydraulically calculated to require 100 gpm at 50 psi - does this work? Does the 13.37 cfm of air @ 50 psi translate to 100 gpm at 50 psi of water?
Dave
Dave
RE: Does 13.37 cfm of water translate to 100 gpm of water?
