Detailed Dimension NEEDED for SAE J1926-1 / ISO 11926-1
I am looking for WHERE I can find DETAILED dimensions on the SAE J19126-1/ISO 11926-1, port holes.
Our drawing callout is:
"2X .469 Dia Thru One Wall
Port Holes per SAE J1926-1 / ISO 11926-1
SAE-8 size Straight Thd Ports (3/4-16 UNF-2B)".
We are having a part issue with leakage, and we want to verify that the vendor made our part correct.  We are making sure the O-ring also is correct.
Not a big company, so I would appreciate ALL the help I can get.
Thank you in advance.
RE: Detailed Dimension NEEDED for SAE J1926-1 / ISO 11926-1
THANK YOU MadMango....I passed it along to Engineering Mgmt, HUGE HELP...
