Using Current Path in a Macro
I'm trying to create a macro (in NX5) to export a step file from a part file.  When I manually export the step file, the current path and filename is automatically put in the export dialogue, but when I run a recorded macro, it inserts the path and filename of the file I wrote the macro with.  Does anyone know if there is a "current_path" and/or "current_filename" type tag that I can use replace the string that gets recorded in the macro.  I tried the "User Input on Dialog Boxes" option, but for some reason, it doesn't work when I open the save dialogue box in the export window.
RE: Using Current Path in a Macro
I have a couple of functions that I use to get the current path and file name.
CODE
Function GetFileName()
    Dim strPath as String
    Dim strPart as String
    Dim pos as Integer
    'get the full file path
    strPath = displayPart.fullpath
    'get the part file name
    pos = InStrRev(strPath, "\")
    strPart = Mid(strPath, pos + 1)
    strPath = Left(strPath, pos)
    'strip off the ".prt" extension
    strPart = Left(strPart, Len(strPart) - 4)
    GetFileName = strPart
End Function
Function GetFilePath()
    Dim pos as Integer
    GetFilePath = strPath
End Function
You can use them within a function or use variables to save the contents like this:
CODE
Dim currentPath as string
Dim currentFile as string
'full path and file name of current file
'currentFile = GetFilePath() & GetFileName() & ".prt"
'path of current file
currentPath = GetFilePath()
'file name (without '.prt') of current file
currentFile = GetFileName()
Thanks for the reply.  That looks great, but I assume that code would need to be run using journaling, and I can't record the export of a step file in journaling, only using basic macro.
Sorry, I read macro in your post and thought journaling.
Have you tried using journaling? I know it can be done in NX6, it is worth a shot in NX5.
I've tried journaling, but step file export is not supported (at least, when I record a journal, I doesn't recognize step file exporting.  I don't know if there is a way to manually code it).
I tried to use your code listed but I'm getting an error that "displayPart" is not declared. Are you importing a specific library or do you define "displayPart" somewhere else?
The code listed previously is a snippet from a larger program. When you create a journal (in NX6) you get this much automatically:
CODE
' NX 6.0.3.6
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
'   Menu: Tools->Journal->Stop Recording
End Sub
End Module
The above code was generated simply by starting to record a journal then stopping the record operation. You can see it automatically creates some useful objects for you to use.
That's how I create the initial macro, using the Journaling function, but its still throwing the error.
What version of NX?
NX 7.0
Are you willing/able to post your code?
CODE
' NX 7.0.1.7
' Journal created by adminuser on Mon Jul 12 14:52:17 2010 Central Daylight Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
    Dim pos as Integer
End Function
    Dim pos as Integer
End Function
Sub Main
For Each fileName As String In My.Computer.FileSystem.GetFiles("C:\Documents and Settings\adminuser\Desktop\CATIA_translated files - Node 2\n2_eclss")
'   Menu: File->Open...
    Dim basePart1 As BasePart
    Dim partLoadStatus1 As PartLoadStatus
    basePart1 = theSession.Parts.OpenBaseDisplay(fileName, partLoadStatus1)
    partLoadStatus1.Dispose()
    Dim markId1 As Session.UndoMarkId
    markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Enter Gateway")
'   Menu: File->Save As...
    Dim partSaveStatus1 As PartSaveStatus
    Dim fileSavepath As String = "C:\Documents and Settings\adminuser\Desktop\Node 2 STP\"
    Dim currentFile As String = GetFileName()
    partSaveStatus1 = workPart.SaveAs(fileSavePath & currentFile & ".stp" )
    partSaveStatus1.Dispose()
'   Menu: File->Close->All Parts
    theSession.Parts.CloseAll(BasePart.CloseModified.CloseModified, Nothing)
    workPart = Nothing
    displayPart = Nothing
Next
End Sub
End Module
Move the declarations out of 'Sub Main' to right under the line: 'Module NXJournal'. This will essentially make the variables global (available to all parts of your code).
CODE
Module NXJournal
Sub Main...
Alternately, you could declare displayPart in each of the functions that use it. This would avoid the use of global variables and their potential problems.
