CTRL + X,C,V
CTRL + X,C,V
CTRL + X,C,V
when i went to AutoCAD 2010, i lost the ability to select and object and control cut/copy/paste with the keyboard. i've tried everything and can't get it back.
RE: CTRL + X,C,V
What does happen? Any reaction in the command line?
Lothar
ADT 2004
RE: CTRL + X,C,V
if an item(s) is selected and i ctrl+c, it just cancels the selection.
RE: CTRL + X,C,V
i remember old school ACAD had Ctrl+C equal to today's "Esc"
RE: CTRL + X,C,V
Did you check your user preferences?
Go to Tools -> Option -> User Preference tab -> Windows Standard Behavior
check the boc for "Window standard accelerator keys"
RE: CTRL + X,C,V
I don't have that block.  The only two blocks under Windows Standard Behavior are 1) double click editing and 2)shortcut menus in drawing area.
RE: CTRL + X,C,V
all the other ctrl+ commands work but those.
RE: CTRL + X,C,V
Hm,
do you have this problem in every dwgs? Open a new one and try again. Did you install the Service Pack 1 for 2010? There are some corrections inside...
Lothar
ADT 2004
