WDPF POWER SUPPLY
WDPF POWER SUPPLY
WDPF POWER SUPPLY
HAVE ANY ONE EXPERIENCE ON REPLACING PIONEER MAGNETIC POWER SUPPLY ON THE WESTINGHOUSE CONTROL SYSTEM THESE DAY PIONEER MAGNETIC IS NOT PRODUCING THIS POWER SUPPLY IS AREAL PAIN TO FIND OUT A REPLACEMENT INTERNET IS FULL UP ON RUBBISH ABOUT THAT . ILL APPRECIATE ANY GOOD TIP
RE: WDPF POWER SUPPLY
Try lower case and punctuation. That may be the best tip you will get to receive an answer on this forum.
Bill
"Why not the best?"
Jimmy Carter
Astec Standard's MP series is pretty close to a drop-in replacement. Same mounting dimensions although the fixing holes on one of the guide rails don't match and the rail has to be drilled to suit. They have an excess of current capability over what the old Pioneer units could provide, and bombproof reliability.
Also if your keyboard is broken you could find one with a working caps lock on ebay for about £5. Otherwise people might think you're SHOUTING at them, which is pretty daft when you're asking us for help. wink
