Computer modelling of rebar
I am looking for software for computer modelling of rebar, a program compatible with Microstation, or AutoCAD, etc..  Want to be able to produce 3D images in addition to plan and section.  I have found only "GEOPAK Rebar" by Bentley and am wondering if anyone knows of other vendors or programs with the necessary capabilities.
RE: Computer modelling of rebar
Try Allplot by Nemetschek. This is the UK site but there are links to their international sites. I havent tried it but it is the only other 3D rebar modeller that I know of.
http://www.nemetschek.co.uk.
Best of luck
I am not aware of other products, but I have used Geopak Rebar and would like to add a word on its true capability in the perspective of your requirements. Firstly, it will NOT produce plans and sections. You will have to draw plans and section in x-y, y-z, x-z planes etc. and the software will generate a 3-d model out of this information, plus a bar-chart. Secondly, it is cumbersome to use (to say the least) when you want multiple sections of a structure at different points.
Be sure what do you want and ask the vendors to deliver it in a demo before making a purchase.
If you want to model a 3-d and cut plans/sections out of it, Microstation (V7 or V8)alone is sufficient for this.
