drilling holes on an structural assembly
Thanks to the guys for having answered my other questions before.
Using Solidworks, I want to drill holes on an assembly of column, beams and plates (or multi-body model of such parts), intending to have perfectly aligned M12 holes cut with the Hole Wizard and plates perfectly mating with the column and beams. What is the easiest or shortest way to do this and Save so that all the parts are holed and the plates cut to shape and the beams cut to proper length?
Also, what do you call that stretched hole intended to accommodate small misalignment between the bolt and the hole?
RE: drilling holes on an structural assembly
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2010 SP2.1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
For slots or oblongs, you can sketch a line and Offset it Bi-directional, Cap the ends to make them faster.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
thread559-271573: curved surface that can be flattened
Van, also, be aware the when you do assembly features such as holes and cuts that you have the option to propagate the feature to the parts which can be handy depending on your design intent.
Dan
www.eltronresearch.com
Dan's Blog
