Symmetry Annotation
Symmetry Annotation
I'm working on some drawings (making new drawings for reference) for a steel arch bridge built back in 1893, and have some of the original shop drawings.
On some of the drawings only one-half of the part is drawn (up to the Centerline) and noted: "SYM ABT CENTERLINE".
Am I right in assuming this means symmetrical about centerline, if so is this annotation still used today?, if not what else would be used.
Many thanks,
Gord
Many thanks,
Gord
RE: Symmetry Annotation
Yes your assumption is correct and I have recently seen CAD drawings using the same terms.
desertfox
What you're talking about is subtly different but I think the idea is still shown in the relevant ASME spec whose number escapes me and I'm not at work to look.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
My CAD system will make a half view and place 2 parallel lines at either end of a symmetry line per either ISO or ASME. I don't know which specific parts of the standards cover this.
Y14.5M-1994 shows what you have described in the figure per my above statement.
Frank
