Check sheet metal part
there is a command or a tools to verify if a sheet metal is flattener-able or if some flange co-penetrate ?
SolidWorks for example doesn't permit during the flange creation to penetrate in other flange or check in the flattering state.
Thank you
Thank you
RE: Check sheet metal part
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
the problem is that the flat-solid is created even if you cannot produce it.
This example that I have attached, even a non-designer eyelid.
For more difficult cases, there is no control?
Check-mate could help me ?
Thank you
Analysis -> Examine Geometry...
...paying particular attention to the 'Consistency', 'Face Intersection' and 'Self-Intersection' results.
John R. Baker, P.E.
Industry Sector
Cypress, CA
it works, but exist an automatic control during the project ?
Something if I'm creating a flange that intersect material, NX doesn't complete the process flange creation ?
Only for curiosity...because sometime some workarounds can help the designer to reduce errors during the study.
Thank you for your help..
John R. Baker, P.E.
Industry Sector
Cypress, CA
thank you..I will study check-mate.
Regards..
