making line intersection points visible
I'm using Solid Edge V20, i have a part that has a corner which has been rounded. I can dimension to the intersection point of the two lines, but i cannot find a way to display the intersection points. I know NX has the tool, does solid edge have a similar tool for showing intersection points between to lines?
I have attached a picture to show what I mean, it is circled in red.
Sean
RE: making line intersection points visible
hang out over the first line then over the second then get close to where the intersection should be and SE will find the intersection point.
I draw lines in the view.
There is no automatic feature to do it.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
