max allowable stress- 316 ss
I am reviewing a design for a piston for an ABS submital. ABS refers to ASME BPVC for allowable stress values.
Can anyone tell me values for:
ASTM A240/A480
ASTM A511
A page reference would also be very helpful, then I can purchase the referenced page(s) from Linda Hall Library without purchasing the entire BPVC-IIA volume.
thanks!
Seton
ASTM A240/A480
ASTM A511
thanks!
Seton
RE: max allowable stress- 316 ss
SA 240 Grade 316 ss @200 deg F 17.3 Ksi (lower sress line used).
SA 480 not in Section II, Part D.
A 511 is not in Section II Part D, and is not an ASME B&PV Code approved material.
thanks, metengr.
I will speak with ABS and ascertain whether our client must burst test the cylinder design or whether there are other avenues available.
