Design Procedure for Drag Strut Connections Tension/Shear
I am looking for a reference that will address the design procedure for beam/girder drag strut connections for tension/compression & beam end shears.
RE: Design Procedure for Drag Strut Connections Tension/Shear
Structural wood design: a practice-oriented approach using the ASD method
Design of wood structures--ASD/LRFD
Breyer
It was my college textbook and I still use it as a reference 13 years later. There is a specific section on drag strut analysis and design.
