Old Problem Fix anyone!?
Hi this post is from 3 years ago. One of our users came up with this error this morning Its very urgent that we get it fixed asap. We think its to do with profile issues unless you can tell me different
All comments apreciated
This is a link to the error
http://www.eng-tips.com/viewthread.cfm?qid=185213&page=144
RE: Old Problem Fix anyone!?
Also its NX6
think
If you set /3gb switch in the boot.ini winXp
you should have fixed the error three years ago,  winky smile
The problem only occured today but i found a post on the same error which dated back to 3 years
You get this error when launching NX or when trying to load a part/assembly? Are other programs running concurrently? How much RAM and swap file space does the computer have? Have you tried rebooting (obvious first response, but I have to ask)?
The error occurs when i open it i have check the ram thats all fine could be the swap file though.
I can get onto NX using my administrator profile but i need to let the engineer access it on his own
