Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
ASTM or ASME Spec for 1.25Cr-0.5Mo in Strip form
TGS4 (Mechanical)
5 May 10 16:32
I have an application (insulation support system for a pressure vessel) where I need to use 1.25Cr-0.5Mo material.  I need this material in 1/8" thick x 2" wide and 3/8" thick x 4" wide strips.
I know that for this material, I have the specification for SA-387, Gr. 11, Class 2 for plate, but I am looking for a strip specification.  I have searched through ASME Section II, Part D, and found bar form in SA-739, Grade B11.  Is the bar specification sufficient for my application, or is there a better specification for the strip?
metengr (Materials)
5 May 10 17:08
TGS4;
The bar specification is not sufficient and not applicable. I don't believe this has to be an ASME SA material specification for this application. All you need is a weldable grade of Cr-Mo strip so check with a steel distributor for stock material in this grade or equivalent or use the ASTM A 387 specification (it does not need to be SA specification).
TGS4 (Mechanical)
5 May 10 17:37
Thanks metengr.  I agree that this application does not need to be the SA- spec.
If I understand you correctly, the A387 spec could be applicable.
I need to make sure that it's the right grade of Cr-Mo for the creep resistance at temperature.
metengr (Materials)
5 May 10 19:04
TGS4;
The A 387 specification should do it. In fact, the Grade 22 plate may be more available and is a slight upgrade in time dependent allowable stress values over Grade 11 plate (1.25% Cr-1% Mo alloy steel).
TGS4 (Mechanical)
5 May 10 19:05
Thanks so much!
Close Box
Join Eng-Tips® Today!
Join Us             Close
