Remeshing for an Axisymmetric model
Hi everyone,
I am new on this forum and also new with Abaqus.
I am trying to run a calculation but it is not really working...
I have a compression in axisymmetric. The load is applied on the rigid body called "piston". The "matrix is not moving.
I would like to remesh the deformable body called "sample".
I have activate the options for the remeshing but it is not working.
Is anyone can help me to make the remesh working please? It would be very helpful.
Another question would be: why, in the job monitor, I don't have anything in columns "ierations" and I have really big numbers in column "increment"? Is it normal?
Thanks for having read my message and I hope someone will help me!^^
Best regards,
Pipo159
Best regards,
Pipo159
RE: Remeshing for an Axisymmetric model
In an implicit simulation Abaqus will set the time increment and not go to the next increment until the current one is small enough that the solution converges. This is the type of simulation that the settings that nemey is referring to.
HTH
Dan
First, thank to both of you for your answer.
Ok I understand why there is no iterations and very large number of increments!
Thanks a lot
Pipo
Thanks in advance for your answer.
Pipo
