Metal Bldg Frame
Metal Bldg Frame
Metal Bldg Frame
Has anyone ever modeled a tapered beam/col frame for a metal bldg?  The nonprismatic beam definition starts and ends with a wide flange section, not sure if this accurate, aren't they welded plate girders?
RE: Metal Bldg Frame
You can model a nonprismatic member in ETABS and use it for analysis. I am not sure it designs the member though.
There's an ETABS FAQ on engineered tapered section on the CSI website under the Support section. Use the "Add" I/Wide flange to use plate girders instead of using standard steel shape from a library
