Delete ordinate dimension
I've created an ordinate dimension and hide the name.
Now...how can I delete this ordinate dimension ?
I can delete single dimension, but not the entire ordinate dimension group.
Thank you..
RE: Delete ordinate dimension
It's been a while since I have worked with ordinate dimensions, but if I remember correctly if I needed to delete all the dimensions in the group I needed to select the name (that you currently have hidden) and select "delete" on your keyboard
Hi jerry1423,
how can I show again the ordinate dimension name ?
Thank you
Go to...
Edit -> Show and Hide -> Show...
...select the Ordinate 'name' and hit OK.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hi John....thank you...
Hi John,
I've tried your solution, but ordinate dimension name is not show.
If I hide a dimension, work...but the name no.
Hi John,
I tested your suggestion on other machine, but doesn't work.
The solution that I found is click on the ordinate dimension command, select one ordinate dimension ang go in the ordinate tab of the style option.
Thank you..
