Mathcad Reference Sheet and API Problems
Hi
I have a mathcad sheet that will read a large block of data from an excel file, then filter based or 2 or 3 search terms. The filtered data is then used in the calculations.
The search terms, and all other variables will be entered via the API from a web interface.
The programming loops etc needed to filter the data do not need to be visible on the sheet, in fact i would prefer it itf they weren't visible as they just confuse matters. I have tried hiding the sections containing the programming loops etc using areas, but this causes problems with the API, it ignores any changes to variables within the hidden sections.
I am experimenting with using the 'Reference' function to reference the original worksheet (with programming loops etc visible) and create a summary worksheet. Standard variables work ok e.g.
Main Sheet -> T:=50
produces
Summary Sheet -> T=50
However, when i call a variable that has been computed or looked up I just get a 'variable not defined' message. When I open the main sheet everything is working fine.
Anybody got any ideas?
Cheers
Main Sheet -> T:=50
produces
Cheers
RE: Mathcad Reference Sheet and API Problems
Cheers
