Interpotation of API 650 û requirement for self-suporting cone roofs
In API 650 - 5.10.5.1 Self-supporting cone roofs,
Do you agree that this paragraph require the roof plate thickness to between 5-13mm? No matter how big the tanks are, the roof plate thickness will never exceed 13mm?
I seem very odd. Compared to the EN14015-10.4.2 the required roof plate thickness is significantly less for tanks with big diameters.
Do anybody have any comments?
RE: Interpotation of API 650 û requirement for self-suporting cone roofs
This is a limit on the maximmum thickness for the roof.  It doesn't mean that a 1/2" thick roof will be sufficient for all tank sizes.  If your calculations say you need a thickner roof you should use a different type of roof (umbrella, dome, structurally supported).
