Is Associativity lost between Pro-E and NX?
Hello all. I am working in Pro-E and need to export to a customer using NX 6.0. Is associativity of a model lost from one program to the next? Can you import one to the other and continue working seamlessly?
RE: Is Associativity lost between Pro-E and NX?
There is no associativity between a NX file and a Pro/E file. When the file is exported to a neutral format, all parametric data of that file is lost and the receiving system only has a dumb solid representation. Editing the faces of that solid is easier on the NX side.
Ben Loosli
