Area of sheet metal
Area of sheet metal
I work the sheet metal to make architectural panels. I need to know the surface (sq. ft) of the piece are painted. I know with the "variable table", using the formula, it's possible to find the area that I want. But the complexity of the formulas become complicated. Is it possible to take the "surface area" in the "physical properties" and divide by 2 ? Which would give me the exact area that I want for all the pieces that I make.
Thank you and excuse my English writing.
RE: Area of sheet metal
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
BTW, what's a '.psm' file?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Best Regards
Hudson
www.jamb.com.au
I'm, working with Solid Edge V20 and i want to know if it's possible to have the surface of this pieces (the surface appears, only half of the surface of all the sheet metal) (see the attachment) automatically and insert the information in "draft". So, if i make a modification, the surface update automatically in my "draft".
Thanks.
