Outside thread
Outside thread
Outside thread
Having trouble creating an outside thread.  Using the thread command on a 0.37 inch diameter, the thread type list is empty.  How do I populate this list if the cylinder diameter is set to one in the thread file?
RE: Outside thread
when the list is empty it indicates that no matching
thread within hole.txt is found. Either you add that
thread to the holes.txt or change the diameter which
has to be done to solve you problem: the correct
diameter is 0.375 and the list will show a couple of
suitable treads
dy
