Relay Test Plans for Doble F6150 test set
thread238-113769: Doble F6150/ProTest Test Plans
We have just installed SEL 300G, 387T, 311L, 487B and 351 relays. I am looking for test plans that will run on a Doble F6150 test set. Does any one have some already created that I could use? Then, how do I get them from you?
RE: Relay Test Plans for Doble F6150 test set
Purely hypotetically I can send you some ProTest test plans for the relays you mentioned but they are for the relays that I've got; and they are different from yours. You will have to re-design those test plans anyway as you relays have different settings and logic. Why don't you just start write your own plans - it's easy. Maybe you should use F6Test.
Thanks for your help.
Not to be negative and/or underestimate your abilities, but those aren't relays that a "real novice" should be testing. It sounds like these relays are going to be protecting some rather expensive equipment $$$ !!
If I was the owner/customer of that plant, I would not allow a novice to test those relays.
In my opinion, you should reconsider what you've gotten yourself into before it's too late.
