testing of f1554 anchor rod
dear sir,
please enlighten me about the method of testing of the anchor bolt/rod that has a nut from one side and a plate from the other end. headed rods are called. do i have to test the whole anchor rod as it is putting the nuts and the plate under tension or i can only put the rod itself under tension.
