Hydro Power plant
Hydro Power plant
Sorry I had try to find my answer for so long but i still can't get it.
Normally how much the speed is require to turn the turbine? Or what is the RPM for the turbine when the water flow thru it?
THanks!
THanks!
RE: Hydro Power plant
Hi samchong87, see the thread1083-260171: Velocity through a water turbine. In the link of that post you can start (or continue) to study the velocity diagrams for hydraulic turbines.
