AutoCAD Fonts - City Blueprint
I like using the City Blueprint font in AutoCAD, it looks hand printed, more traditional and less sterile than many other choices.  The problem is it can be hard to read.  Is it possible to get it in BOLD type or change to heavier line weights?
RE: AutoCAD Fonts - City Blueprint
Remember, these fancy fonts use a lot of memory and will slow down printing to a trickle sometimes.  I normally stay with regular fonts such as TXT or RomanS.
Thanks guys.
Exxit: To check out the city-blueprint file, do I just open the zipped file into the AutoCAD directory or is there more to it?
