NX 7.5 is now available for download
In case you had not yet heard, NX 7.5 is available for download from the GTAC website. Of course you will need a new updated license 'sheet' before you can actually run the software, however if your maintenance is up-to-date you can request one from your CSR (Customer Service Representative) at Siemens or from the distributor where you get your support.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: NX 7.5 is now available for download
When can we expect it? Also for CAMEXPRESS users?
Greetings, Bert
John R. Baker, P.E.
Industry Sector
Cypress, CA
Anyone not on the subscription service will have to download both the software and documentation from the GTAC download site (or get it from your distributor if you've worked out a different deal with them).
Anyway, that's where it stands at the moment.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I listen that NX7.5 permit to modify the hole type, but in the what's new it's not mentioned.
Are you in planning to add this opportunity in the next QRM ?
The same on sheet metal flange, that after selected the width option and created it, the option is grayed.
I need to edit the sketch.
Planning for this ?
Regards..
No, that is NOT true. However, there is a project to offer this in NX 8.0 (in fact, I just got the notice to review the functional spec for the project).
As for your Sheet metal question, I'm not sure what you mean. When you edit a Flange, you have the option to edit the sketch.
John R. Baker, P.E.
Industry Sector
Cypress, CA
what is the scope of NX7.5 ?
NX7 is fresh...NX8 is on developing.
NX7.5 is not a NX7 patch, then ?
This intermediate release is focused for ?
Thank you...
It's a full release, containing a significantly higher number of enhancements and new capabilities than did NX 7.0 (the reality is that NX 7.5 is perhaps the 'largest' NX/UG release ever in terms of R&D effort expended). The confusing numbering scheme was the result of an executive-level decision mandated by a non-technical situation.
If anything, NX 7.0 is more like an 'intermediate' release being that it was released on Windows only while both NX 6.0 and NX 7.5 are avialable on ALL currently supported platforms; Windows(32-bit), Windows(64-bit), Linux(64-bit) and MacOS.
And as for 'scope', the projects and enhancements cover virtually all applications areas and modules of NX.
John R. Baker, P.E.
Industry Sector
Cypress, CA
as you have mentioned, the number release make confusion, but reading the what's new, I confirm lot of enhancement.
I would like NX7.5, but we have just installed NX7.
Regards....
Ray S
NX 7.0.1.9
www.appliedprecisionproducts.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Is that true?
If so good job on that and I hope that just means NX is just going to continue to blow away the competition!
appray@sbcglobal.net
TIA
Ray S
NX 7.0.1.9
It's in the mail. Good luck.
John R. Baker, P.E.
Industry Sector
Cypress, CA
ht
John R. Baker, P.E.
Industry Sector
Cypress, CA
It's in the mail. Have fun.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks for your input.
Deborah
Anyway, that's my 2 cents on tht topic
John R. Baker, P.E.
Industry Sector
Cypress, CA
Please explain what this mean ! Can I download the NX on my computer and what is the price for software and/or license ?
Also what are the minimum hardware recomandation for NX7.5 ?
Now if you are NOT a current customer of Siemens PLM Software, may I suggest that you go to...
http://www.plm.automation.siemens.com/en_us/
...where you can find where you can call to get more information from either a Siemens PLM Software representative or if you're located in a region where we sell our products through distributors, you can follow-up with one of them. To help direct you to where you can learn more, first select the 'Siemens PLM Software' link at the left side of the page under the main advert image and select your country. Then select the 'Contact' link in the center of the page for information about how to contact our locals offices.
Good luck and I hope we can help you.
John R. Baker, P.E.
Industry Sector
Cypress, CA
What do you think about de NX4 and NX6 on linux, talk about Good and bad points. And the windows 7?
I used both in linux Suse and Ubuntu.
Thanks a lot.
However, as far as NX is concerned, running on Windows 7 has not been a problem and the performance has been very good. And before anyone asks, while the oldest version that I've done a full install from scratch with was NX 6.0, I've copied over images of all the versions back to UG V16.0 and they all seem to work fine with the possible exception of UG V17.0 which throws an error when it starts about some missing library file, but once I accept the error it continue to load and eventually runs just fine. Now I have to admit that some of the older releases would probably have issues connecting to the latest version of MS Excel, but everything seems to work fine with at least NX 5.0 forward.
And yes, due to running both pre- and post-NX 5.0 versions I'm having to run both the old and the new license servers on my laptop, again with no apparent problems.
All in all, from what I've seen, Windows 7 is a step up from even XP (despite having to find everything all over again ;-)
John R. Baker, P.E.
Industry Sector
Cypress, CA
A customers was out of maintenance and want to re-enter with the new NX7.5.
I was astonished about the performance.
All it's flasy!
... obviously the V18 user interface sound a little odd to me...
I'm really happy to swap the performance with the new Block Based UI.
