How to hide a Part in a drawing from Browser_2010
Before 2010 I could simply right click the part or assembly in the browser and uncheck visible? The visible command is still there but grayed out.
How can I hide a part I dont want to show in the drawing?
I dont like levels of detail, and I would like the part to remain visable in the assembly.
Matthew
Matthew
RE: How to hide a Part in a drawing from Browser_2010
Generally this isn't good practice, your view should be associative. Hence you should do as rollupswx suggested and set up VewReps.
However there will always be some occasions where it is required.
But I still belive its more complicated then way it was in 2008.
However like said above it is a better workflow to simply create design view reps in the model to control the visibility of an idw view.
Matthew
If unchecked a parts visibility can be toggled in the IDW or in the assembly. (the visible option can be toggled on/off) Changing the visibility in the drawing will not change the visibility in the model.
It is a better workflow to have it checked but there are situations when it is easier to have it unchecked.
For example suppose you have an assembly that you want to have a cover shown in the front view but not shown in the top view. In this case I would uncheck the associated box.
