erase cutter compensation form postpro
One of my postprocessador, is taking out cutter compensation
I don't know why because on NXCAM I don't put cutter compensation.
For example a 100mmx100mmx100mm block is taken 110mmx110mmx110mm, I am just using a D=10mm ball,
compensation is r=5 in all corners, how can I saay no to this compensation on postbuilder?
Thanks.
Thanks.
RE: erase cutter compensation form postpro
igor should let the broker tool "0" because the software is already compensating
Now if you want to compensate with the effective radius of the cutter have to set the output compensation cuting contact traking milling time she goes over the profile but offset radius of 5 mm
Andre
specialist and multi axis
development of IS & V
and postprocessors
member committee nxcam plm world
skype:andrenxcam7
i see email understand you want put compensation
i go fix the sent you
i go sent you
Andre
and postprocessors
skype:andrenxcam7
