Pack and Go with Drawings
To copy a assembly structure to another location
I use Find References. Problem is that this does not
copy drawings. How to copy the "real" assy structure
with drawings?
BR
Linqur
with drawings?
BR
Linqur
RE: Pack and Go with Drawings
Are the parts and or assemblies in-contexted in any way?
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help first*
with drawings in SW Explorer either.
Lets assume there is no in-ccontexting.
My VAR has told me that SW does not allow
Pack and Go of assembly including drawings
and offered to sell his custom program.
I wonder if there are any free ways?
BR,
Linqur
Inside of SW Explorer, have you done this...?
Click the browse button, and open the ASSEMBLY of what you want to copy.
Click on the Edit pulldown, then on Copy Document.
Click on the "Copy Children" checkbox.
Click the "Find Where Used" Checkbox, which opens a seperate "window" below.
Click on the "Find Now" button, and you should see the drawing and it should already have a checkmark to copy it also.
Let us know if this gets what you need...
Mr. Pickles
this takes a lot of time (depending on structure of course)
because it searches through all files in given path to find drawing references. BUT it is not able to find drawings of
parts and subassys. It finds only drawing of assy to be copied.
BR,
Linqur
The only way I have any luck with this is to open every assembly and part and drawing that I want to transfer and then start "saving as . . ." from the bottom up. In other words, open the assembly and all drawings. Edit each part in turn as do a "save as" to the new number and in the new directory. Refs in the assembly and drawings will be changed. Do a save as for each of the drawings. Finally do a save as for the assembly. This is a huge PITA!
Any better ideas?
Crashj 'all the world wonders' Johnson
Or at least I do on a 900 part assembly. The parts find the ones that they need to find first, so I don't have mis-represented parts/mates/in-contexts going on. Course, you may want all their names changed to, but I don't change them. Heck, they are in a different directory anyway.
Mr. Pickles
Crashj 'nuts I say NUTS' Johnson
I think I'll call my old Inventor VAR and tell him Solidworks can't copy drawings. I'm sure they will be all ears,
Hey, I'm just kidding folks.
Mr. Pickles
FYI. In Pro/E when you do a save as on a part or assembly it automatically copies the drawing to the new filename. So this is just something that SolidWorks hasn't figured out how to make it happen yet. I'm sure they will get it done sooner or later. This sounds like a good enhancement request.
Mike
SW does not put refering information to
"master" file. Meaning that drawing knows
where is the model it is made for but model
does not know where is its drawing.
Though you have possibility to RMB open
drawing from models window but this works only
when drawing is situated in same folder or
any predefined folder for drawings.
So if I have got it right then solution for
full pack and go would be searching for drawings
in predefined folders by predefined rules for
naming.
BR,
Linqur
