Center to center dimension
I draw lamp and I want to easily show the pin center to center dimensions. Currently I draw a tiny line perpendicular from the center of each pin and then dimension these. But am I missing something here? Is there an easier way? I am on SW2010 SP2.1.
drawn to design, designed to draw
RE: Center to center dimension
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
