Can you identify this material?
Hey Guys,
I was wondering if you guys could offer any advice, the surface condition of the test sites could have been better. Could anyone take a stab at what material this might be? Parent material is 317SS. Three tests were taken.
PMI Results
Mo- 4.9%   5.3%   6.9%
Ni- 28.9%  36.9%  34.5%
Fe- 50.3%  42.8%  44.4%
Mn- 1.0%   1.3%    0.9%
Cr- 13.5%  11.9%  12.0%
Any advice at all would be apreciated. Hoping to get a grinder on the test piece tomorrow. I shall post the results.
Thanks in advance,
Dave
RE: Can you identify this material?
Can you give information as to what this component is or function? This would help.
Considering PMI ( by Niton or Spectrum or other devices ) give only  an idea about the alloy - mainly if a calibration  had been  poor - and doens't supply a right chemical composition, it seems that this alloy could be:
°) UNS N 08904 , EN 1.4539( Ni= 26% Cr= 19 % Mo =5%)
  or
°) UNS N 08926 , EN 1.4529  Ni= 26% Cr=19% Mo = 6%)
In any case , both of above grades would have respectely Cu = 0,7  and Cu = 1,5%
Verify if this last elements were detected by PMI.
Finally, I point out that a PMI test is a method to confirm an alloy after a calibration using  a specimen of that alloy to confirm.
Thanks for your assistance guys, after preparing the surface results came back 316ss.
