Vertical Curve calc.s
I am always on the lookout for a rdwy vertical curve spreadsheet.
If any are known, please advise.
RE: Vertical Curve calc.s
athomas236
Vertical Curve data (V.P.I. Sta., Length, Elevation, Design Speed) this info is used in calculating a road or bridge grade/elevation on Centerline/Profile Grade Line... at a certain point.
It is time consuming to calculate this long hand. There is software available ($$$) that can do this, however I am certain it can be accomplished with-in excel.
Take an afternoon and code it. It is straight forward. If you are looking for a freebie, search your local/state DOT website.
