Abaqus and progressive failure analysis on composite material plate|
hi to everyones
I'm preparing a progressive analysis model of a composite laminate plate with a hole in the middle using pyton in Abaqus.
the problem is that I don't know how I can change the material properties only on the elements that are failure. After the first analysis I know the element number and layer that are failure in each element, so now I have to modify their properties to do next step of the analysis. How can I do? also in the interactive mode! I did the same thing with APDL for ANSYS and it was simpler (maybe because I know better ANSYS- APDL than ABAQUS-PYTON!!)
Sorry for my english and thanks so much to everyone.
RE: Abaqus and progressive failure analysis on composite material plate|
David R. Dearth, P.E.
Applied Analysis & Technology
