trouble plotting nested loop results
hi,
I am relatively new to matlab and have created a code for a problem using loops however I want to display the results of each iteration as a graph. I can plot as dots by using hold on/hold off - effectively just overlaying numerous single point graphs. does anyone know how I can get the results to display as a continuos line graph.
the code I have is:
%Inputs
Hi=8;
Qin=xlsread('data')
A=223453;
Hd=18;
Qout=5.26*24*60*60/1000
%Calcs
V=Hi*A/1000
Vmax=A*Hd/1000
%reset ii (index value)
if V>=0.9*Vmax
    ii=1
else ii=0
end
while ii<155
    if V<0.9*Vmax
        ii=ii+1;
    end
 hold on
        plot (ii,V)
   if V>=0.9*Vmax
               while V>0.7*Vmax && ii
                      ii=ii+1;
                      if V+Qin(ii)-Qout*3 > Vmax
                         V=Vmax
                      else V=V+Qin(ii)-Qout*3
                      end
                end
   elseif V>=0.3*Vmax
               V=V+Qin(ii)-Qout
               if V>=Vmax
                  V=Vmax
               end
   else
            V=V+Qin(ii)
            while V<0.5*Vmax && ii<155
                      ii=ii+1;
                      if Qin(ii)> (Vmax-V)
                          V=Vmax
                      else V=V+Qin(ii)
                      end
            end
                   if V<0.9*Vmax
                   end
   end
end
hold off
RE: trouble plotting nested loop results
thanks for trying to help, I tried inserting this command into my code but still can't get it to display a graph. where abouts in the code should I have inserted the
Vplot(ii)=V?
where you had the other plot line. You might need pause(0.1) as well, and you can get rid of the hold on statements.
Needless to say, since I can't run the code I can't check it.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
awesome that worked thanks heaps
Possibly connected...
I often want to animate a 2D plot.  It can be done nicely using handles.
p=plot(x,y);
set (p,'erasemode','xor');
% Animation loop
for %some loop counter
  set(p,'ydata',somNewYvalue);
end
On the same subject, the Matlab "drawnow" function can be used to force a plot update.
- Steve
Ah, much more elegant than pause(0.1)
Incidentally have you found a way of forcing octave to print to the terminal during a run? I'm using 3.0.1 and it tends not to print out intermediate results until the run has finished.
Cheers
Greg Locock
