WHAT AND HOW CAN YOU LINK INFORMATION TO NOTES
I am wondering what I can link to notes. I am interested in the following right now, but would like to know more.
how to insert a dimension in a note, like from another sheet.
how to insert the file name/location, current date and current sheet.
I am aware of file>properties and then attributes, but I have to type everything in. I am sure UG should know the file name, date, page number or name of sheet or other information without me telling it. Any info would be helpful.
RE: WHAT AND HOW CAN YOU LINK INFORMATION TO NOTES
thread561-217972: Automatic drawing text
thread561-221681: Automatic Text (Date Control String)
thread561-228567: Automatic Attribute annotations - title block values
These turned up when I did a search on 'automatic text', there might be more that are of use to you. Try varying the search terms a bit to refine your results.
Do you have WAVE?
What version of NX are you on?
I am on NX6 and in when I open up "note" there is a relationship icon - it is a bit hard to find at first, it is the right icon, of four icon, in the "symbol" menu.
You may want to play with that a bit.
also do a search for "part attributes" using the search feature located just above here, and under the name of this thread
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
some tricks , thing to know?
TIA
And exactly what size 'tubes' would that be?
Sorry, I couldn't resist
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I want to have Information about the tabular label.
Those tabular labels are inside NX for a long time.
I have attached a picture to get it right.
What are the benefits to use? Tricks an tipps around.
tia
Here is a good thread that should answer your questions:
http://www.eng-tips.com/viewthread.cfm?qid=228567
It is the same one cowski posted above
_____________________________
In de expression editor (in modeling -> Ctrl-E) create the following expressions (all type string):
MyDate = StringUpper(dateTimeString("localTime?", True))
MyDay = subString(MyDate, 9, 10)
MyMonth = subString(MyDate, 5, 7)
MyYear = subString(MyDate, 21, 25)
MyTimeStamp = MyDay + " " + MyMonth + " " + MyYear
Then in Drafting pasted this text into a note: <X0@MyTimeStamp>
It seems like that is the current date as of now. Is it possible to get the date that the file was either created or last saved?
