Assembly Properties to Part Properties
I have created Assemblies of purchased components and added the properties such as description, supplier, etc to the assembly. I now need to save the assembly as a part file. How can I do this and transfer the same properties to the part file without having to add them one by one?
RE: Assembly Properties to Part Properties
Updated "copy custom info" macro coming out Monday-ish.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Thanks guys. Macduff, I got your graphic but in my document properties box for both the part and the assembly, only the "Load from External File" is available. Also the ANSI-STI PART is not on the drop down menu. Any suggestions?
ANSI-STI PART is a file i created. Let me get back to you on saving.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 4.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
