Save part with new coordinate system
Good morning guys,
In solidworks, i can save my model in parasolid file with the new pre-defined coordinate system. Could some body please show me how in done in soldedge ST2?.
Thanks in advance
Tinhman
Thanks in advance
Tinhman
RE: Save part with new coordinate system
As far as iI know I don't think is possible , but you can change the origin (0,0,0)and more in edge bar doing right click on on assemly name and " occurence properties". You can also "save copy as " existing assembly and change in new assembly if you don't want changes in original assembly.
hope something is useful for you
good day
You should open a new part file and create a new coordinate system (where the part will be). You should use Part copy command and use the coordinate system option (what you cretaed) in the dialog box.
