Phase Shifting Transformers
I'm doing a high level review of options to increase transmission capacity into an area and am aware that phase shifting transformers may provide a solution.  Does anyone know of any links to papers where I could get some more information on the theory and operation of phase shifting transformers?
Thanks in advance, StR
RE: Phase Shifting Transformers
Check the IEEE Std C57.135-2001: "Guide for the Application, Specification and Testing of Phase Shifting Transformers"
To help your searching check under "phase-angle regulator (PAR) is the device most often used. PAR is also referred to as a power-angle regulator, or phase shifter."
For your reference see the enclosed article related to Utility Practice Using Phase Sifting Transformers.
https://www.npcc.org/PublicFiles/LakeErieRedispatch/CurrentYear/Phase%20Angle%20Regulator%20Operation%20-May%202000.pdf
Most recently there are improvement in the performance of conventional phase-shifting transformer adding reactive reactance in parallel to form a simple application of the Interface Power Control Technology (IPC) . For more details, see the enclosed publication
http://www.ewh.ieee.org/reg/7/www_lark/publ/canrev/canrev34/IPC.pdf
A classical reference is the T&D Reference Book by Westinghouse on Chapter 5 Part XIII.
