Running user defined subrutine in Abaqus 6.7-1
Hi
 I try to run my user defined subrutine in Abaqus 6.7-1,but I have encountered with an error message:
ABAQUS ERROR:
Unable to create a temporary directory" C:\program files\intel\..." to be used for scratch files.
how can I solve it? please help if you have any suggestion.
RE: Running user defined subrutine in Abaqus 6.7-1
Isn't the scratch file directory defined in the abaqus.env file? Check that file and the manual for the correct definition (as I don't have it with me now).
Tata
Make sure your subroutine file is in the same directory as your input file. That should fix it.
thanks for your helpful suggestions.that problem has solved.
but I encountered with new problem:
when I submit the subroutine to Abaqus I have encountered with an error message:
unknown keyword "usersubroutine"....AMBIGUOUS KEYWORD.
How I can solve it? please can anyone help me?
