Brine pit and Flare Pit
I would like to know about the function of brine water at LPG flare pit?
What kind of material(metal) can be used for protection shield behind the flare pit?
RE: Brine pit and Flare Pit
Nothing, other than a way to dissipate energy when flaring, like they use sea water under the ehgines of the suttle or other rockets.
Protection shield?I assume a way to reflect radiant heat?  Anything that withstand the radiant heat.  Steel, concrete, a wall of water.
Thanks Dcasto,
Coul yo please tell me more about High temperature resistant and Brine corrosion resistant paint or coating?
I don't remeber what we used to coat our lines and brine pump impellars.  If I stubble across it, I'll post.  Just look up pump internal coatings.
